Installing PowerBook G4 Aluminum 17" 1-1.67 GHz Logic Board
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 4
This motherboard includes all ports on the right side except USB.
first image
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
