Installing PowerBook G4 Aluminum 17" 1-1.67 GHz Battery
  • Author: iRobot
  • Difficulty: Very easy
  • Add Note x
All you need to remove the battery is your fingers!
first image
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
For more information, check out the PowerBook G4 Aluminum 17" 1-1.67 GHz device page.
Did you successfully follow this guide?
Related Products
Notes Add Note Notes are offturn on
