Installing PowerBook G4 Aluminum 15" 1.67 GHz Hard Drive
  • Add Note x
  • x 51
Want more storage capacity? Replace your hard drive with a higher capacity unit.
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 3  ¶
  • Remove the memory compartment cover.
  • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
Next » « Previous
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
