Installing PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card
Add Note Introduction
This guide will show you how to replace the DC & Sound Card on your PowerBook.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Upper Case
  • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Step 3
  • Remove the memory compartment cover.
  • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
Add NoteNotes: Introduction
Flag Reply by ewoudenberg Sep 7 @ 1:42 PM
The Tools Used list specifies a #6 Torx wrench, but in step 7 it says a 1.5mm hex wrench is preferred. This is good to know ahead of time since a #6 Torx wrench is not available from the local hardware store, but a 1.5mm hex wrench is.
Add NoteNotes: Step 3
Flag Reply by gepkes Aug 3 @ 11:59 PM
I had 7mm screws here instead of 12mm. Did without them till later.
Flag Reply by Polanskiman 3 days ago
I have an Aluminum PowerBook G4 1.67Ghz since 2006.
3/4 (from bottom to top) of the LCD becomes either black or is jumbled each time I turn on the MAC or move the screen. I need to press the LCD at several locations in order for this problem to go.... any advice ?
