Installing PowerBook G4 Aluminum 15" 1.5-1.67 GHz Modem
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
56k internal modem, standard on all models.
Sections
Files
first image
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Upper Case  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
first image
Add Note Edit Step 4  ¶
  • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Remove the three 3 mm Phillips screws.
  • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
first image
Add Note Edit Step 5  ¶
  • Turn the computer 90 degrees clockwise so that the hinge faces you.
  • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
first image
Add Note Edit Step 6  ¶
  • Rotate the computer 90 degrees clockwise, so that the ports face you.
first image
Add Note Edit Step 7  ¶
  • Turn the computer over and open the display.
  • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
first image
Add Note Edit Step 8  ¶
  • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
  • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
first image
Add Note Edit Step 9  ¶
  • Rotate the upper case up and toward the screen, so that the upper case rests against it.
first image
Add Note Edit Step 10  ¶
  • Remove the orange tape securing the trackpad ribbon to the logic board.
  • Disconnect the trackpad ribbon from the logic board.
  • Remove the upper case from the computer.
first image
Add Note Edit Step 11 — Hard Drive  ¶
  • Remove the three long silver Phillips screws from the retaining bracket on the left side of the optical drive.
  • Remove the retaining bracket.
first image
Add Note Edit Step 12  ¶
  • Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
first image
Add Note Edit Step 13  ¶
  • Lift the hard drive up from the right side and remove it from the computer.
first image
Add Note Edit Step 14 — Modem  ¶
  • Remove the two silver Phillips screws from the modem board.
  • The screw in the top left corner has a black washer.
first image
Add Note Edit Step 15  ¶
  • Disconnect the large orange ribbon cable from the top of the modem.
first image
Add Note Edit Step 16  ¶
  • Lift the modem up and disconnect the remaining cable, at which point the modem will be free.
For more information, check out the PowerBook G4 Aluminum 15" 1.5-1.67 GHz device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
