Installing PowerBook G4 Aluminum 15" 1-1.5 GHz Upper Case
Add Note Introduction
Changing the top case will also give you a new trackpad. Depending on the replacement case, you can also use backlit keyboards.
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to turn the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Upper Case
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Step 3
  • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 9 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
Notes
There are no notes
