Installing PowerBook G4 Aluminum 15" 1-1.5 GHz RAM
Author:
iRobot
- Difficulty: Easy
Accessing the RAM is easy and requires only a Phillips screwdriver.
Embed this guide
With the HTML code below, you can embed this guide as a small widget on your website.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
This guide has been completed 21 times.
