Installing PowerBook G4 Aluminum 15" 1-1.5 GHz LCD
- Author: Walter Galan
- Difficulty: Very difficult
Save money by just replacing your broken LCD element.
Sections
- Battery 1 step
- Rear Display Bezel 11 steps
- Display Inverter 2 steps
- LCD 8 steps
Files
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2
Rear Display Bezel
The following procedure allows the changing of the rear display bezel without removing the display assembly from the computer. Do not attempt to rotate the display back farther than the hinges allow or your computer may be damaged.
Open the computer with the display facing you and rotate the display back as far as possible.
Remove the T6 Torx screw from the bottom left corner of the display assembly. The computer casing will not allow the screwdriver to be inserted directly into the screw, so be careful not to strip the screw.
Page 1 of 8
