Installing PowerBook G4 Aluminum 15" 1-1.5 GHz Display
Introduction
| Difficulty: | Difficult |
Change out the entire display assembly, including the inverter, Airport antenna, hinges and metal casing.
Do you actually need to remove any of the screws on the underneath if you're just replacing a PRAM battery, or a hard drive? Aren't those only required if you're taking the whole logic board out?
