Installing PowerBook G4 Aluminum 12" 1-1.5 GHz EMI Finger
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
Small metal finger located beneath the memory door.
first image
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — EMI Finger  ¶
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
first image
Add Note Edit Step 3  ¶
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
For more information, check out the PowerBook G4 Aluminum 12" 1-1.5 GHz device page.
Did you successfully follow this guide?
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Mini DVI to DVI Adapter
$14.95 · 2 in stock
12.7 mm PATA 8x SuperDrive
$89.95 · 34 in stock
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
Arctic Silver ArctiClean
Notes Add Note Notes are offturn on
