Installing PowerBook G3 Wallstreet Heat Shield
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
Removing the heat shield enables access to the RAM and processor beneath.
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Remove both expansion bay modules using the levers on the front of the computer.
  • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
  • Pull the tabs toward yourself and the keyboard will pop up.
first image
Add Note Edit Step 2  ¶
  • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
  • Rest the keyboard on the trackpad.
first image
Add Note Edit Step 3  ¶
  • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
  • 2) After disengaging the locking bar, slide the cable out of the connector.
first image
Add Note Edit Step 4  ¶
  • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
first image
Add Note Edit Step 5  ¶
  • Slide a spudger or screwdriver downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
  • Once the strain relief cables are free, lift the keyboard off.
first image
Add Note Edit Step 6  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 7 — Heat Shield  ¶
  • Remove the two Phillips screws from the heat shield.
  • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
first image
Add Note Edit Step 8  ¶
  • Grasp the metal handle on the heat shield and pull up and toward yourself.
For more information, check out the PowerBook G3 Wallstreet device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
