Page 1 of 1
Installing PowerBook G3 Wallstreet Fan
- Author: iRobot
- Difficulty: Difficult
Changing the fan isn't easy, but keeping your fan working will keep your laptop cool and operational.
Sections
- Keyboard 6 steps
- Heat Shield 2 steps
- Hard Drive 3 steps
- Processor 1 step
- Modem 3 steps
- Clutch Cover 2 steps
- Display 5 steps
- Upper Case 5 steps
- Power Card 1 step
- DC & Sound Card 1 step
- Fan 2 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 1
Keyboard
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Edit
Step 12
Processor
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
Edit
Step 26
Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
Page 1 of 1
