Page 1 of 1
Installing PowerBook G3 Wallstreet Clutch Cover
- Author: iRobot
- Difficulty: Easy
How to access the PowerBook G3 Wallstreet Clutch Cover.
Sections
- Keyboard 6 steps
- Heat Shield 2 steps
- Hard Drive 3 steps
- Processor 1 step
- Modem 3 steps
- Clutch Cover 2 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 1
Keyboard
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
Edit Step 12
Processor
Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
Remove the processor by sliding it up and to the right.
The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
Page 1 of 1
