Installing PowerBook G3 Lombard Clutch Cover
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
How to remove and replace the PowerBook G3 Lombard Clutch Cover.
Sections
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Turn the computer so that the ports are facing you.
  • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
first image
Add Note Edit Step 2  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
first image
Add Note Edit Step 3  ¶
  • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
  • In order to replace the keyboard, you must first remove the modem.
first image
Add Note Edit Step 4 — Heat Shield  ¶
  • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
first image
Add Note Edit Step 5  ¶
  • Lift the heat shield up and pull it toward you.
first image
Add Note Edit Step 6  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 7 — PRAM Battery  ¶
  • Pull the battery cable directly up from the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the battery from its holder by pulling up and to the left.
first image
Add Note Edit Step 9 — Modem  ¶
  • Remove the two silver Phillips screws from the modem.
first image
Add Note Edit Step 10  ¶
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
first image
Add Note Edit Step 11  ¶
  • Disconnect the cable from the right side of the modem.
first image
Add Note Edit Step 12  ¶
first image
Add Note Edit Step 13 — Processor  ¶
  • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
first image
Add Note Edit Step 14  ¶
  • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
  • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
first image
Add Note Edit Step 15  ¶
first image
Add Note Edit Step 16 — RAM  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the RAM chip out.
  • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
first image
Add Note Edit Step 17 — Hard Drive  ¶
  • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
  • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
first image
Add Note Edit Step 18  ¶
  • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
first image
Add Note Edit Step 19 — Clutch Cover  ¶
  • Push the display back so that it lies flat.
first image
Add Note Edit Step 20  ¶
  • Slip a spudger or your index finger under the clutch cover near the power button and pull gently upward until you feel it come free.
  • Repeat the previous step on the left side.
first image
Add Note Edit Step 21  ¶
  • Lift the clutch cover up and off, rotating it toward yourself.
For more information, check out the PowerBook G3 Lombard device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
