Page 1 of 1
Installing Power Mac G5 Power Supply
User-Contributed Guide
This guide is not managed by iFixit staff.
- Author: Adam
- Difficulty: Moderate
This guide will detail how to remove the Apple G5's main power supply.
Sections
- Side Panel 4 steps
- Front Fan Assembly 2 steps
- Bottom Right Cooling Fan Unit 7 steps
- Processor and Cooling Unit 5 steps
- Power Supply 9 steps
- View:
- Paginated
- Full width
Edit
Step 8
Remove the G5 metal cover from the processing/cooling unit of the computer. NOTE: Apple inserted a rather fragile plastic pin that inserts through the top divider shield and clips into a tab on the hidden ledge of this CPU shield. Removing this pin, certainly voided Mac's warranty - but more appropriate for now, voids most after-market insurance plans. A replacement pin (new) is hard to get ahold of, and very few are talented and patient enough to remove this pin without damaging it. Just something to keep in mind. If you have no warranty any longer or don't care, please continue...
Pull the metal plate to the left and outward to remove the plate from the processing/cooling unit.
Edit
Step 10
Unplug the fan's power cable from the upper rightmost corner of the motherboard (connection J45). If there is a video card in place, carefully pull the cable plug down between the back edge of the video card and the motherboard. Note, the photo shows the unplugged cable and the area it plugs into outlined in yellow. No video card is shown in this photo.
Edit
Step 16
Pull the cooling/processing unit straight up to prevent damage to logic board
This will require some effort and should be done with caution to avoid damage.
The sleeves around the 6 screws may hold it in, if so just take a pair of needle nose pliers and gently squeeze the sleeves until it releases.
Pull the bottom, then side towards the bottom of the CPU case, first to move around the bottom coolant sleeve around the heat sinking bracket. *heat sinking bracket not in picture*
Edit
Step 18
NOTE: Here are the standoffs without the cooling unit installed to make it easier to understand where the screws are located. Remove the bottom 2 standoffs so it is easier to remove the power supply.
Check the pin connections for any damage. All the pins highlighted in yellow should appear straight up and not appear bent. DON'T TOUCH THE PINS. A bent pin will result in your computer not powering on.
This guide has been completed 26 times.
Page 1 of 1
