PlayStation 3 Hard Drive Replacement
Replace the hard drive on your PS3.
  • Add Note x
  • x 15
Use this guide to replace your PlayStation 3's hard drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Hard Drive Backup  ¶
  • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
  • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
  • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
  • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
  • Navigate the XMB to the 'Settings' menu and select 'System Settings'
  • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2 — Hard Drive  ¶
  • Use the flat end of a spudger to pry the hard drive door away from the lower case.
  • Remove the hard drive door from the PS3.
first image
Add Note Edit Step 3  ¶
  • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Grab the hard drive pull tab and pull the hard drive toward the front face of the PS3.
  • Pull the hard drive assembly out of the PS3.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5 — Hard Drive Replacement  ¶
  • Remove the four 4.3 mm Phillips screws securing the hard drive cage to the hard drive.
  • These 4 screws can sometimes be very difficult to remove. If you strip the heads our Screw Extracting Pliers remove the damaged screws nicely.
first image
Add Note Edit Step 6  ¶
  • Remove the hard drive from its steel cage.
  • If you're installing a new hard drive into your PS3, use this guide to restore the data you backed up.
For more information, check out the PlayStation 3 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
