Page 1 of 1
Installing PSP Go Logic Board
- Author: Miroslav Djuric
- Time required: 45 minutes
- Difficulty: Moderate
If your PSP Go's logic board failed, you're in luck. Use this guide to get it fixed!
Sections
- Back Cover 2 steps
- Top Cover 1 step
- Left Trigger 2 steps
- Battery 3 steps
- Logic Board 8 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2 ¶
Use an PSP Go opening tool around the perimeter of the back cover to loosen it on all sides.
Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
Edit Step 6
Battery
Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
Use the PSP opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
Edit Step 7 ¶
Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
Wedge a PSP opening tool in between the connector and logic board, and gently pull the connector upwards.
Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
Edit Step 13 ¶
Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
Edit Step 16 ¶
Use a PSP opening tool to disconnect the display cable from the logic board.
The D-pad may come loose while prying the logic board.
The logic board should now be free from the rest of the device.
During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
Page 1 of 1
