Installing PSP Go Directional Pad
  • Add Note x
Use this guide to remove the PSP Go's directional pad buttons.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Back Cover  ¶
  • Unscrew the four Phillips screws on the back of the PSP Go.
  • Rotate the PSP so you can see the top of the device.
  • Unscrew the two Phillips screws next to the volume buttons.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use an PSP Go opening tool around the perimeter of the back cover to loosen it on all sides.
  • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
  • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
first image
Add Note Edit Step 3 — Top Cover  ¶
  • Pull the top cover upwards gently from its housing.
first image
Add Note Edit Step 4 — Left Trigger  ¶
  • Use a PSP opening tool to gently flip up the left trigger connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6 — Battery  ¶
  • Do not peel the sticker away from the left EMI shield. It will expose the "VOID VOID" lettering that will void your warranty!
  • Use the PSP opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
first image
Add Note Edit Step 7  ¶
  • Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
  • Wedge a PSP opening tool in between the connector and logic board, and gently pull the connector upwards.
  • Make sure not to disconnect the white connector socket on the logic board, and just the connector itself.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Use a PSP opening tool to pop out the battery, being careful not to snag the "Warranty Void" sticker in the process.
  • When putting a new battery into the PSP Go, make sure you hold the "Warranty Sticker" so you don't put the battery on top of it.
first image
Add Note Edit Step 9 — Logic Board  ¶
  • Remove the single Phillips screw securing the logic board to the inner case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Use a PSP opening tool to gently flip up the right trigger connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Use a #00 Phillips screwdriver to unscrew both bottom plate screws.
  • Remove the bottom plate by lifting it away from the device.
first image
Add Note Edit Step 12  ¶
  • Remove both headphone jack and analog joystick screws using your #00 Phillips screwdriver.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Be very careful when disconnecting the following cables. The connectors do not have flip-up tabs; just hold each cable steady and pull it out of the connector.
  • Unplug the volume button cable using a pair of tweezers. Be careful not to damage the cable.
  • Unplug the Start/Select button cable the same way. Make sure to grasp the black plastic pull tab of the cable.
first image
Add Note Edit Step 14  ¶
  • Use a pair of tweezers to pull out the battery's clear plastic cover.
  • Notice the little metal tab and slot (marked in red) where the clear plastic cover slides into. Make sure you slide the cover into place properly when reassembling the PSP Go.
first image
Add Note Edit Step 15  ¶
  • The logic board is still connected to the display, so do not fully remove it from its housing!
  • Gently lift the logic board slightly out of its housing.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16  ¶
  • Use a PSP opening tool to disconnect the display cable from the logic board.
  • The D-pad may come loose while prying the logic board.
  • The logic board should now be free from the rest of the device.
  • During reassembly, make sure to properly line up the power button with the power button lever on the logic board.
first image
Add Note Edit Step 17 — Directional Pad  ¶
  • Use a PSP opening tool to take out the directional pad buttons.
For more information, check out the PSP Go device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
