PSP 300x Motherboard Replacement
  1. PSP 300x Motherboard Replacement, Battery: step 1, image 1 of 3 PSP 300x Motherboard Replacement, Battery: step 1, image 2 of 3 PSP 300x Motherboard Replacement, Battery: step 1, image 3 of 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Motherboard Replacement, Front Casing: step 2, image 1 of 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Motherboard Replacement: step 3, image 1 of 2 PSP 300x Motherboard Replacement: step 3, image 2 of 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Motherboard Replacement: step 4, image 1 of 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Motherboard Replacement: step 5, image 1 of 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Motherboard Replacement: step 6, image 1 of 2 PSP 300x Motherboard Replacement: step 6, image 2 of 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x Motherboard Replacement, LCD Screen: step 7, image 1 of 2 PSP 300x Motherboard Replacement, LCD Screen: step 7, image 2 of 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. PSP 300x Motherboard Replacement: step 8, image 1 of 3 PSP 300x Motherboard Replacement: step 8, image 2 of 3 PSP 300x Motherboard Replacement: step 8, image 3 of 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  9. PSP 300x Motherboard Replacement: step 9, image 1 of 2 PSP 300x Motherboard Replacement: step 9, image 2 of 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
  10. PSP 300x Motherboard Replacement: step 10, image 1 of 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Motherboard Replacement, Trigger Buttons: step 11, image 1 of 1
    • Remove the screw securing 'L' trigger to the PSP.
  12. PSP 300x Motherboard Replacement: step 12, image 1 of 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. PSP 300x Motherboard Replacement: step 13, image 1 of 1
    • Remove the 'L' trigger from the PSP.
  14. PSP 300x Motherboard Replacement: step 14, image 1 of 1
    • Remove the screw securing the 'R' trigger.
  15. PSP 300x Motherboard Replacement: step 15, image 1 of 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. PSP 300x Motherboard Replacement: step 16, image 1 of 1
    • Remove the 'R' trigger from the PSP.
  17. PSP 300x Motherboard Replacement, Analog Stick: step 17, image 1 of 1
    • Remove the screw from the bottom left edge of the PSP.
  18. PSP 300x Motherboard Replacement: step 18, image 1 of 1
    • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
  19. PSP 300x Motherboard Replacement: step 19, image 1 of 2 PSP 300x Motherboard Replacement: step 19, image 2 of 2
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
  20. PSP 300x Motherboard Replacement: step 20, image 1 of 1
    • Remove the cable from the connector and remove the entire black piece from the PSP.
  21. PSP 300x Motherboard Replacement: step 21, image 1 of 1
    • Remove the screw holding the analog stick in place.
  22. PSP 300x Motherboard Replacement: step 22, image 1 of 2 PSP 300x Motherboard Replacement: step 22, image 2 of 2
    • Flip up the lock on the analog sticks ribbon cable.
    • Remove the analog stick from the PSP.
  23. PSP 300x Motherboard Replacement, Button Pad: step 23, image 1 of 1
    • After removing the LCD Screen, the Button Pad should be easy to remove.
  24. PSP 300x Motherboard Replacement, Power Jack: step 24, image 1 of 1
    • Flip up the lock and detach the ribbon cable above the power jack.
  25. PSP 300x Motherboard Replacement: step 25, image 1 of 1
    • Remove the screw from the power jack.
  26. PSP 300x Motherboard Replacement: step 26, image 1 of 1
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
  27. PSP 300x Motherboard Replacement: step 27, image 1 of 1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
  28. PSP 300x Motherboard Replacement, Speaker: step 28, image 1 of 2 PSP 300x Motherboard Replacement, Speaker: step 28, image 2 of 2
    • Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker.
    • The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
    • Make sure the new/replacement speaker does not spring out during reassembly.
  29. PSP 300x Motherboard Replacement, Motherboard: step 29, image 1 of 1
    • Remove the cable carefully by lifting upwards from port attached to the motherboard .
  30. PSP 300x Motherboard Replacement: step 30, image 1 of 1
    • Flip up both of the locks and remove both cables as shown
  31. PSP 300x Motherboard Replacement: step 31, image 1 of 1
    • Flip up the lock and remove the ribbon cable located at the bottom edge of the PSP.
  32. PSP 300x Motherboard Replacement: step 32, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
  33. PSP 300x Motherboard Replacement, Remove Power Switch Panel: step 33, image 1 of 3 PSP 300x Motherboard Replacement, Remove Power Switch Panel: step 33, image 2 of 3 PSP 300x Motherboard Replacement, Remove Power Switch Panel: step 33, image 3 of 3
    • Remove the screw located at the top of the power switch panel.
    • Gently lift and remove the panel from the switch side
  34. PSP 300x Motherboard Replacement: step 34, image 1 of 1
    • Remove the silver rim on the right side of the PSP.
  35. PSP 300x Motherboard Replacement: step 35, image 1 of 1
    • Remove the silver rim on the left side of the PSP.
  36. PSP 300x Motherboard Replacement: step 36, image 1 of 2 PSP 300x Motherboard Replacement: step 36, image 2 of 2
    • Remove the motherboard from the PSP
16 other people completed this guide.
mbnewsom
3,430 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 90
Past 30 Days: 361
All Time: 50,820
