Page 1 of 1
Installing PSP 2000 Logic Board
User-Contributed Guide
This guide is not managed by iFixit staff.
- Author: espinks
- Time required: 15-30 minutes
- Difficulty: Difficult
Is your logic board acting illogical? Fix it!
Sections
- Battery 1 step
- Front Casing 4 steps
- Display 2 steps
- Memory Stick Slot 2 steps
- Speaker 1 step
- Logic Board 3 steps
- View:
- Paginated
- Full width
Edit Step 2
Front Casing
This step requires the removal of the warranty sticker. Removing the sticker will void the warranty.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Under the sticker is a 5mm Phillips screw needed in the next step.
Edit Step 5 ¶
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Edit Step 7 ¶
With the home bar out of the way, gently pry up the display using the opening tools.
There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
Gently lift out the display.
Edit Step 8
Memory Stick Slot
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
Slide off the left trigger along with the plastic bracket underneath.
Carefully pry off left trigger button using opening tools.
The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
Edit Step 11
Logic Board
Remove the following four connections:
Two ribbon cables -- flip up latch and remove horizontally.
One wire clamp -- use an opening tool to pry it up vertically.
One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector.
Page 1 of 1
