Page 1 of 1
Installing Nintendo Wii Motherboard
Private
This guide will not appear in search results but can still be viewed by anyone!
Missing Steps
This guide is incomplete or missing critical steps.
User-Contributed Guide
This guide is not managed by iFixit staff.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Replacing the Wii's motherboard.
- Author: iDeleted
- Time required: 45 minutes to 1 hour
- Difficulty: Difficult
Once the Wii's motherboard is accessible, there are a number of components that can be easily removed and replaced, including the optical drive cables, heat sink, and Bluetooth board.
Sections
- Outer Case 12 steps
- Fan 3 steps
- Optical Drive 5 steps
- Wi-Fi Board 11 steps
- Motherboard 3 steps
Tools
Tools (continued)
- View:
- Paginated
- Full width
Edit
Step 31
The Wi-Fi board is connected to the motherboard by a connector and some adhesive. Pull firmly upward on the board and it will pop off the motherboard.
The Bluetooth and Wi-Fi antennas are connected to the bottom of the Wi-Fi board, and are easily removed by using a spudger to lift them off their respective sockets.
Edit
Step 34
The motherboard is now loose. Lift it up and off the bottom case of the Wii.
The heat sink is held to the motherboard by the thermal paste between it and the processors. Pull it straight up with slight wiggling to free it.
A connector and strip of adhesive hold the Bluetooth board to the motherboard. Prying the board up with a spudger easily removes it.
Use the flat end of a spudger to flip up the black tab on the ZIF connector holding the optical drive data cable to remove it.
Pull directly away from the connector to remove the optical drive power cable.
When replacing the motherboard, be sure to replace the small foam block underneath the power input jack.
Page 1 of 1
