Installing Nintendo Wii Fan
Private
Private
This guide will not appear in search results but can still be viewed by anyone!
Missing Steps
Missing Steps
This guide is incomplete or missing critical steps.
User-Contributed Guide
This guide is not managed by iFixit staff.
Internal cooling fan replacement.
  • Author: iDeleted
  • Time required: 20 minutes
  • Difficulty: Easy
  • Add Note x
  • x 3
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Outer Case  ¶
  • Loosen Phillips screw on bottom of Wii to remove battery case.
  • The screw is captive to the battery case and will not come out; leave the two connected.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • On the bottom side of the Wii, use metal spudger to remove the following:
    • One rubber foot
    • Three plastic stickers.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Remove the following screws:
    • Two 8.1 mm silver tri-wing screws, one under battery case and one under bottom right sticker.
    • Two 5.0 mm silver Phillips screws, under top center and top right stickers.
    • One 5.8 mm black Phillips screw, under top left foot.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • On the right side of the Wii, use the metal spudger to remove the following:
    • Two rubber feet.
    • Two plastic stickers.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
    • Two 8.2 mm silver tri-wing screws, under top left and bottom left feet.
    • Two 8.2 mm black tri-wing screws, under top right and bottom right stickers.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the two doors on top of the Wii by opening them, then applying pressure behind the hinges. The hinges should pop out without much resistance.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Remove the following screws from the top of the Wii:
    • One 5.9 mm black Phillips screw, closest to front of Wii.
    • Two 4.0 mm black Phillips screws.
first image
Add Note Edit Step 8  ¶
  • Remove the black plastic shield from the top of the Wii. Slide it away from the front of the Wii to free the covered end.
first image
Add Note Edit Step 9  ¶
  • Remove the following screws from under the black plastic shield:
    • Two 8.2 mm silver tri-wing screws.
    • Two 5.0 mm silver Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • The faceplate is now loose, but is still connected to the body by the faceplate LED power cable.
  • Open faceplate and disconnect cable from the connector. Using tweezers may make this easier. Set faceplate aside.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Set the Wii on its right side, with the ATI label in the upper left corner.
  • The plastic outer case is now loose. Pull it straight up and off the Wii.
first image
Add Note Edit Step 12  ¶
  • The inner metal shield is now loose as well. Lift it straight up and off the Wii; this may require some wiggling.
first image
Add Note Edit Step 13 — Fan  ¶
  • Remove the two 11.2 mm silver Phillips screws securing the fan to the Wii.
first image
Add Note Edit Step 14  ¶
  • Disconnect the cooling fan power cable.
  • Pull directly up on the cable to avoid damaging the cable connector.
first image
Add Note Edit Step 15  ¶
  • Remove the fan.
For more information, check out the Nintendo Wii device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
