Installing Nintendo Wii Wi-Fi Board
Private
Private
This guide will not appear in search results but can still be viewed by anyone!
Missing Steps
Missing Steps
This guide is incomplete or missing critical steps.
User-Contributed Guide
This guide is not managed by iFixit staff.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
Replacing the Wi-Fi card in the Wii.
  • Author: iDeleted
  • Time required: 45 minutes
  • Difficulty: Difficult
  • Add Note x
The steps in this guide outline the procedure to remove the Wi-Fi board in the Wii. The Wi-Fi and Bluetooth antenna cables both attach to this board, so this guide can also be used to replace them.
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Outer Case  ¶
  • Loosen Phillips screw on bottom of Wii to remove battery case.
  • The screw is captive to the battery case and will not come out; leave the two connected.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • On the bottom side of the Wii, use metal spudger to remove the following:
    • One rubber foot
    • Three plastic stickers.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3  ¶
  • Remove the following screws:
    • Two 8.1 mm silver tri-wing screws, one under battery case and one under bottom right sticker.
    • Two 5.0 mm silver Phillips screws, under top center and top right stickers.
    • One 5.8 mm black Phillips screw, under top left foot.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • On the right side of the Wii, use the metal spudger to remove the following:
    • Two rubber feet.
    • Two plastic stickers.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
    • Two 8.2 mm silver tri-wing screws, under top left and bottom left feet.
    • Two 8.2 mm black tri-wing screws, under top right and bottom right stickers.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Remove the two doors on top of the Wii by opening them, then applying pressure behind the hinges. The hinges should pop out without much resistance.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7  ¶
  • Remove the following screws from the top of the Wii:
    • One 5.9 mm black Phillips screw, closest to front of Wii.
    • Two 4.0 mm black Phillips screws.
first image
Add Note Edit Step 8  ¶
  • Remove the black plastic shield from the top of the Wii. Slide it away from the front of the Wii to free the covered end.
first image
Add Note Edit Step 9  ¶
  • Remove the following screws from under the black plastic shield:
    • Two 8.2 mm silver tri-wing screws.
    • Two 5.0 mm silver Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • The faceplate is now loose, but is still connected to the body by the faceplate LED power cable.
  • Open faceplate and disconnect cable from the connector. Using tweezers may make this easier. Set faceplate aside.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Set the Wii on its right side, with the ATI label in the upper left corner.
  • The plastic outer case is now loose. Pull it straight up and off the Wii.
first image
Add Note Edit Step 12  ¶
  • The inner metal shield is now loose as well. Lift it straight up and off the Wii; this may require some wiggling.
first image
Add Note Edit Step 13 — Fan  ¶
  • Remove the two 11.2 mm silver Phillips screws securing the fan to the Wii.
first image
Add Note Edit Step 14  ¶
  • Disconnect the cooling fan power cable.
  • Pull directly up on the cable to avoid damaging the cable connector.
first image
Add Note Edit Step 15  ¶
  • Remove the fan.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16 — Optical Drive  ¶
  • Remove the four 9.2 mm silver screws mounting the optical drive to the Wii.
  • A magnetic screwdriver or pair of tweezers is very helpful to ensure the recessed screws make it all the way out.
first image
thumb image 1
thumb image 2
Add Note Edit Step 17  ¶
  • The optical drive is loose, but is still connected by a power cable and a data cable.
  • With the Wii aligned as pictured, rotate the near end up to reveal the connections underneath.
first image
Add Note Edit Step 18  ¶
  • Disconnect the 12-pin white power cable connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 19  ¶
  • Flip up the tab on the optical drive data cable's ZIF connector on the board on the underside of the drive.
  • Remove the optical drive data cable from the drive.
first image
Add Note Edit Step 20  ¶
  • Remove the optical drive from the Wii.
first image
thumb image 1
thumb image 2
Add Note Edit Step 21 — Wi-Fi Board  ¶
  • Remove the nine 10.0 mm black Phillips screws securing the black plastic mounting brackets to the Wii.
first image
thumb image 1
thumb image 2
Add Note Edit Step 22  ¶
  • Free the Bluetooth antenna by undoing the tape binding the black antenna cable to the Wii.
  • The Bluetooth antenna cable is still connected to the Wii; set the antenna aside nearby.
first image
Add Note Edit Step 23  ¶
  • Lift the mounting bracket off the heat sink.
first image
thumb image 1
thumb image 2
Add Note Edit Step 24  ¶
  • Carefully remove the Wi-Fi antenna from the mounting bracket by spreading the two small tabs that hold the antenna board in place and pulling the board straight out.
first image
Add Note Edit Step 25  ¶
  • Remove the small metal bracket from below the fan mount.
  • Remove the metal heat sink shield.
first image
Add Note Edit Step 26  ¶
  • Remove the three 7.25 mm silver Phillips screws from the holes marked "□".
first image
Add Note Edit Step 27  ¶
  • Remove the mounting bracket that holds the Bluetooth antenna cable.
first image
Add Note Edit Step 28  ¶
  • There is a small silver nut loosely contained by the left black plastic bracket; be careful not to lose it.
  • Lift the left black plastic bracket off the Wii, being aware of the silver nut. Pull the bracket's tab toward you where the antenna wires protrude to remove it.
first image
Add Note Edit Step 29  ¶
    • Two 11.3 mm silver Phillips screws from holes marked "Δ".
    • 11 7.25 mm silver Phillips screws from holes marked "↓".
first image
Add Note Edit Step 30  ¶
  • Lift the main EMI shield off the Wii's motherboard.
first image
Add Note Edit Step 31  ¶
  • The Wi-Fi board is connected to the motherboard by a connector and some adhesive. Pull firmly upward on the board and it will pop off the motherboard.
  • The Bluetooth and Wi-Fi antennas are connected to the bottom of the Wi-Fi board, and are easily removed by using a spudger to lift them off their respective sockets.
For more information, check out the Nintendo Wii device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
