Installing MacBook Unibody Model A1342 Lower Case
  • Add Note x
  • x 11
Replacing your lower case is easy! It only takes 8 screws.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
  • Slightly lift the lower case near the vent opening.
  • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
  • The location of these three clips is shown in the third picture.
For more information, check out the MacBook Unibody Model A1342 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
