Page 1 of 1
Installing MacBook Unibody Model A1342 AirPort/Bluetooth Board
- Author: Walter Galan
- Difficulty: Moderate
Wireless connectivity issues? Use this guide to replace an inoperative AirPort/Bluetoo
Sections
- Lower Case 2 steps
- Battery 1 step
- Rear Vent 3 steps
- Rear Speaker Assembly 9 steps
- AirPort/Bluetooth Board 1 step
Tools
- View:
- Paginated
- Full width
Edit Step 2 ¶
The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
The location of these three clips is shown in the third picture.
Edit Step 3
Battery
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
It may be easier to use your fingernails to lift up on both sides of the connector.
This guide has been completed 3 times.
Page 1 of 1
