Installing MacBook Unibody Model A1278 Hard Drive Cable
  • Add Note x
  • x 6
This guide will show you how to remove the hard drive cable from your laptop.
Sections
first image
Add Note Edit Step 1 — Access Door  ¶
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Edit Step 2  ¶
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Edit Step 3 — Battery  ¶
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the white plastic tab and pull the battery up and out of the Unibody.
first image
Add Note Edit Step 4 — Lower Case  ¶
  • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
first image
Add Note Edit Step 5  ¶
  • Using both hands, lift and remove the lower case off the upper case.
first image
Add Note Edit Step 6 — Optical Drive  ¶
  • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
first image
Add Note Edit Step 7  ¶
  • Disconnect the camera cable by pulling the male end straight away from its socket.
first image
Add Note Edit Step 8  ¶
  • Use a spudger to pry the optical drive connector straight up off the logic board.
first image
Add Note Edit Step 9  ¶
  • Remove the two Phillips screws securing the subwoofer to the upper case.
  • The longer of the two screws is on the right.
first image
Add Note Edit Step 10  ¶
  • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
  • Lift the subwoofer off the optical drive, and set it above the computer.
first image
Add Note Edit Step 11  ¶
  • Remove the two Phillips screws securing the camera cable bracket to the upper case.
  • The leftmost screw may remain captive in the camera cable.
first image
Add Note Edit Step 12  ¶
  • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
first image
Add Note Edit Step 13  ¶
  • Lift the optical drive from its right edge and pull it out of the computer.
  • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
first image
Add Note Edit Step 14 — Hard Drive Cable  ¶
  • Remove the single Phillips screw securing the hard drive bracket to the upper case.
  • This screw is captive in the hard drive bracket.
first image
Add Note Edit Step 15  ¶
  • Lift the hard drive by its plastic pull tab and remove the freed hard drive bracket.
first image
Add Note Edit Step 16  ¶
  • Lift the hard drive out of its supports and disconnect the SATA cable by pulling the connector straight away from the hard drive.
first image
Add Note Edit Step 17  ¶
  • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
first image
Add Note Edit Step 18  ¶
  • Lift the mid wall out of the upper case.
first image
Add Note Edit Step 19  ¶
  • Use a spudger to pry the hard drive cable connector straight up off the logic board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 20  ¶
  • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
  • During reassembly, be sure the two pins on top of the plastic retaining block mate to the holes on the underside of the midwall.
For more information, check out the MacBook Unibody Model A1278 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
