Installing MacBook Unibody Hard Drive Cable
Add Note Introduction
This guide will show you how to remove the hard drive cable from your laptop.
Tools used in this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Access Door
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Step 2
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Step 3 — Battery
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the white plastic tab and pull the battery up and out of the Unibody.
Notes
There are no notes
