Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 AirPort Extreme
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 3
Install an AirPort Extreme 802.11g card internally.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the four identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove.
first image
Add Note Edit Step 5  ¶
  • Remove the following six screws:
    • Two T6 Torx screws on either side of the RAM slot.
    • Four Phillips screws along the hinge.
first image
Add Note Edit Step 6  ¶
  • Remove the four Phillips screws on the port side of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
first image
Add Note Edit Step 8  ¶
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
first image
Add Note Edit Step 9  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
first image
Add Note Edit Step 10  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board.
  • Remove the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11 — AirPort Extreme  ¶
  • Disconnect the two antenna cables attached to the AirPort Extreme card.
  • The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
  • If you have a MacBook Pro 17" Model A1229 or A1212, there are three antenna cables attached to the AirPort Extreme card instead of two.
first image
Add Note Edit Step 12  ¶
  • Remove the single black T6 Torx screw from the top right corner of the AirPort Extreme card.
first image
Add Note Edit Step 13  ¶
  • Lift the AirPort Extreme card up and slide it out of its connector.
For more information, check out the MacBook Pro 17" Models A1151 A1212 A1229 and A1261 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
