Page 1 of 1
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement
- Author: iRobot
- Difficulty: Moderate
The ins and outs of replacing your upper case.
- View:
- Paginated
- Full width
Edit Step 9 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit Step 19 ¶
If you have a MacBook Pro 17" Model A1151 or A1212, refer to the first picture to remove the ten identical Phillips screws attaching the keyboard to the casing.
If you have a MacBook Pro 17" Model A1229, refer to the second picture to remove the twelve identical Phillips screws attaching the keyboard to the casing.
Edit Step 20 ¶
If you have a MacBook Pro 17" Model A1151 or A1212, refer to the first picture. There are four locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
If you have a MacBook Pro 17" Model A1229, refer to the first picture. There are six locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
Page 1 of 1
