Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 36
Two RAM slots allow up to 2 GB of PC2-5300 RAM.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the four identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — RAM  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
first image
Add Note Edit Step 5  ¶
  • Pull the chip directly out from its connector.
  • If there are two RAM chips installed, repeat the above procedure for the second chip.
For more information, check out the MacBook Pro 17" Models A1151 A1212 A1229 and A1261 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
