Page 1 of 1
Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 PRAM Battery
- Author: iRobot
- Difficulty: Difficult
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Optical Drive 3 steps
- PRAM Battery 2 steps
Tools
- View:
- Paginated
- Full width
Edit Step 9 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit Step 13 ¶
Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Page 1 of 1
