Installing MacBook Pro 15" Unibody Late 2008 and Early 2009 Optical Drive Replacement
Add Note Introduction
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
Tools used in this guide
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Access Door
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Step 2
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Step 3 — Battery
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
Add NoteNotes: Step 1
Flag Reply by aguib Aug 17 @ 2:09 PM
The A1286 has no Access Door.!!
I actually can see no sign of the battery!...
Flag Reply by lgc90 Sep 10 @ 5:25 PM
Quote from aguib:
I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
Flag Reply by irishking Nov 6 @ 6:56 PM
when will there be a guide for the other unibody macbook pro. that does not have an access door?
