MacBook Pro 15" Unibody Mid 2009 Hard Drive Replacement
- Author: Andrew Bookholt
- Difficulty: Moderate
Upgrade your hard drive for more storage space.
- View:
- Paginated
- Full width
Edit
Step 3
Battery
Three special five-point Torx screws secure the battery to the upper case.
Use Apple specialty tool 922-9101 or iFixit's 5-point Torx driver to remove the two exposed five-point Torx security screws along the top edge of the battery.
A common 1.5 mm flathead screwdriver also works well enough to remove the screws.
You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
Page 1 of 4
