Installing MacBook Pro 15" Unibody Late 2008 and Early 2009 Logic Board Replacement
Add Note Introduction
This motherboard includes all ports on the left side.
Tools used in this guide
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Access Door
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Step 2
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Step 3 — Battery
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
Add NoteNotes: Step 1
Flag Reply by aguib Aug 17 @ 2:09 PM
The A1286 has no Access Door.!!
I actually can see no sign of the battery!...
Flag Reply by lgc90 Sep 10 @ 5:25 PM
Quote from aguib:
I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
Flag Reply by irishking Nov 6 @ 6:56 PM
when will there be a guide for the other unibody macbook pro. that does not have an access door?
