Installing MacBook Pro 15" Unibody Late 2008 and Early 2009 Lower Case
Add Note Introduction
Replace the aluminum bottom case in a MacBook Pro Unibody.
Tools used in this guide
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Access Door
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Step 2
  • The access door should now be raised enough to lift it up and out of the Unibody.
first image
Add Note Step 3 — Battery
  • Be sure the access door release latch is vertical before proceeding.
  • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
Add NoteNotes: Step 1
Flag Reply by aguib Aug 17 2009 @ 2:09 PM
The A1286 has no Access Door.!!
I actually can see no sign of the battery!...
Flag Reply by lgc90 Sep 10 2009 @ 5:25 PM
Quote from aguib:
I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
Flag Reply by irishking Nov 6 2009 @ 6:56 PM
when will there be a guide for the other unibody macbook pro. that does not have an access door?
Flag Reply by Max Dec 12 2009 @ 8:48 AM
Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
Max
Flag Reply by ahothabeth Jan 8 @ 1:05 AM
On other guides you state the height of the HD that can be supported, e.g. http://www.ifixit.com/Guide/Repair/Insta...-MacBook-Pro-15-Inch-Core-2-Duo-Model-A1211-Hard-Drive-Replacement/459/1 , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
Can you confirm this?
Many thanks in advance.
