MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement
Replace the optical drive in your acBook Pro 15" Unibody 2.53 GHz Mid 2009.
  • Add Note x
  • x 5
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
Add Note Edit Step 3 — Battery  ¶
  • Three special five-point Torx screws secure the battery to the upper case. They can be removed with this special driver.
  • If you don't have the special 5-point tool, a common 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head. If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
  • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
first image
Add Note Edit Step 4  ¶
  • Remove the two exposed five-point Torx security screws along the top edge of the battery.
first image
Add Note Edit Step 5  ¶
  • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Torx security screw hidden underneath.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
  • Do not try to completely remove the battery just yet.
first image
Add Note Edit Step 7  ¶
  • Tilt the battery back enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
first image
Add Note Edit Step 8 — Optical Drive  ¶
  • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
  • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
first image
Add Note Edit Step 9  ¶
  • Disconnect the camera cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
first image
Add Note Edit Step 10  ¶
  • Peel the camera cable off the adhesive securing it to the optical drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
  • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the Bluetooth board/cable retainer assembly out of the upper case.
first image
Add Note Edit Step 13  ¶
  • Use a spudger to pry the optical drive connector straight up off the logic board.
first image
Add Note Edit Step 14  ¶
  • Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Lift the optical drive from its left edge and pull it out of the computer.
first image
Add Note Edit Step 16 — Optical Drive Replacement  ¶
  • Remove the optical drive cable by pulling it straight away from the optical drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
For more information, check out the MacBook Pro 15" Unibody 2.53 GHz Mid 2009 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
