Page 1 of 1
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive Replacement
- Author: Walter Galan
- Difficulty: Moderate
Upgrade your hard drive for more storage space!
- View:
- Paginated
- Full width
Edit Step 3
Battery
Three special five-point Torx screws secure the battery to the upper case. They can be removed with this special driver.
If you don't have the special 5-point tool, a common 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head. If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
Edit Step 11
Remove two T6 Torx screws from each side of the hard drive (four screws total).
You'll need to transfer these screws to your new hard drive if you're changing drives.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Page 1 of 1
