Installing MacBook Pro 15" Model A1150 Heat Sink
Add Note Introduction
The heat sink helps keep the processor cool and happy.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Step 2 — Memory Door
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Step 3
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Add NoteNotes: Step 1
Flag Reply by rpbetancourt Mar 7 @ 12:56 PM
Before beginning, I found some small plastic bags and labeled each of the with the location the screws would come from once removed and the appropriate step number. Once the screws were removed I placed them in the labeled bags and did not have to worry about mixing screws up. Also, provided a good way to insure that no steps were skipped in the reverse process
