Installing MacBook Pro 15" Model A1150 Display Data Cable
Add Note Introduction
Difficulty: Very difficult
Display connection issues? Use this guide to replace a faulty display data cable rather than replacing the entire display.
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Step 2 — Memory Door
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Step 3
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Add NoteNotes: Step 1
Flag Reply by rpbetancourt 5 days ago
Before beginning, I found some small plastic bags and labeled each of the with the location the screws would come from once removed and the appropriate step number. Once the screws were removed I placed them in the labeled bags and did not have to worry about mixing screws up. Also, provided a good way to insure that no steps were skipped in the reverse process
