Page 1 of 1
Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board
This guide has more recent changes. Switch to the latest unverified version.
- Author: Walter Galan
- Difficulty: Difficult
Provides power to the machine and includes all ports on the left side of the machine.
Sections
- Battery 1 step
- RAM Shield 1 step
- Upper Case 7 steps
- Left Fan 3 steps
- ExpressCard Cage 9 steps
- Left I/O Board 1 step
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 8
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Edit
Step 9
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal. Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
Remove the upper case.
Page 1 of 1
