Page 1 of 1
Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left Ambient Light Sensor
- Author: Walter Galan
- Difficulty: Moderate
This detects the light level in the room to adjust the backlit keyboard.
Sections
- Battery 1 step
- RAM Shield 1 step
- Upper Case 7 steps
- Left Ambient Light Sensor 2 steps
Tools
- View:
- Paginated
- Full width
Edit Step 8 ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Edit Step 9 ¶
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal. Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
Remove the upper case.
Edit Step 11 ¶
Remove the single silver Phillips screw securing the clear plastic shield over the left ambient light sensor.
Lift the clear plastic shield off the left ambient light sensor.
Use a spudger to pry the left ambient light sensor board out of its housing on the left speaker.
Lift the left ambient light sensor board out of the computer.
Page 1 of 1
