Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Assembly
Add Note Introduction
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Step 2 — Ram Shield
  • Remove the three identical Phillips screws from the memory door.
  • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
first image
Add Note Step 3 — Upper Case
  • Remove the two Phillips screws in the battery compartment near the latch.
Add NoteNotes: Step 1
Flag Reply by ColmillodeChile Nov 6 @ 12:09 PM
Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
