Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Assembly
  • Add Note x
  • x 36
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
first image
thumb image 1
thumb image 2
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical 2mm Phillips screws from the memory door.
  • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 3 — Upper Case  ¶
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
first image
Add Note Edit Step 4  ¶
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
first image
Add Note Edit Step 5  ¶
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
first image
Add Note Edit Step 6  ¶
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 8  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal. Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
first image
Add Note Edit Step 10 — Display Assembly  ¶
  • Disconnect the two antenna cables attached to the Airport Extreme card.
  • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
first image
Add Note Edit Step 11  ¶
  • Deroute the Airport antenna cables from their channel in the left speaker.
  • The gray wire with the black tip appears to have no connection.
  • On some models the gray wire is connected to the airport card.
first image
Add Note Edit Step 12  ¶
  • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
first image
Add Note Edit Step 13  ¶
  • Support the display with one hand while removing the following screws:
    • One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
    • One 9.2 mm full thread T6 Torx screw securing the iSight cable ground loop to the fan.
first image
Add Note Edit Step 14  ¶
  • Disconnect the inverter cable from the left I/O board by placing a spudger beneath the cable and lifting up.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Disconnect the display data cable from the logic board.
  • Remove the foam bumper from the top of the right hinge of the display.
first image
Add Note Edit Step 16  ¶
  • Remove the silver 9.2 mm T6 Torx securing the ground loop in the display data cable to the casing.
first image
Add Note Edit Step 17  ¶
  • Support the display with one hand while removing the following screw:
first image
Add Note Edit Step 18  ¶
  • Grasp the display assembly on both sides and lift it up and out of the computer.
For more information, check out the MacBook Pro 15" Core 2 Duo Models A1226 and A1260 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
