Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Bluetooth Antenna
Add Note Introduction
Replace the Bluetooth board.
Parts relevant to this guide
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Battery
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Step 2 — Ram Shield
  • Remove the three identical Phillips screws from the memory door.
  • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
first image
Add Note Step 3 — Upper Case
  • Remove the two Phillips screws in the battery compartment near the latch.
Add NoteNotes: Step 1
Flag Reply by ColmillodeChile Nov 5 @ 6:09 PM
Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
