Installing MacBook Pro 15" Core 2 Duo Model A1211 RAM Shield
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 3
Removing a few screws will remove this part and allow access to your RAM.
Sections
Tools
Relevant parts
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
For more information, check out the MacBook Pro 15" Core 2 Duo Model A1211 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
