Installing MacBook Pro 15" Core 2 Duo Model A1211 Left Ambient Light Sensor
Introduction
| Difficulty: | Difficult |
This detects the light level in the room to adjust the backlit keyboard.
Tip for new players - print this guide, then use Sello tape to tape the screws from each step on the picture. Keeps them all organised and easy to know which screws belong to which step when putting it all back together
It's one word: Sellotape, the biggest brand in Europe. :-)
In regard to the incredible amount of TINY screws, get an Ice Cube Tray or something with AT LEAST 8 compartments, then, when taking out the screws, mark EACH compartment with the step # and how many screws that were taken out, and used for THAT STEP (such as Step # 3 = 4 of 4 screws. Label EACH compartment, and keep them in line of each step. When it comes time to put everything back together, just reverse your Ice Cube Tray, and follow the Steps in Reverse!
As far as marking each compartment, try these POST IT PENS!!!
http://www.staples.com/Post-it-Flag-Ballpoint-Pen-2-Pack/product_SS1042869?cmArea=SC1:CG25:D...
GOOD LUCK! Take your time, it's not as difficult as it seems!
JerseyJeepGurl
This guide helped me to remove the keyboard on my MBP, but it doesn't take you further to take the keyboard apart. If you REALLY want to look inside the keyboard, you'll need to remove additional phillips screws (10), and carefully remove the inner plastic/clear layers inside the keyboard.
I did this to look for physical damage inside the keyboard and noticed that the black plastic? sheet was torn on my letter 'v', which was one of the keys not working. I did not see any physical sign anywhere else on the keyboard, though.
So, after pulling the defective keyboard away and installing the new one purchased from iFixit, putting everything back together is not too difficult, just reverse.
One thing, though: Check and double-check before you tighten the case screws to make sure your keyboard backlight is working. I noticed I had forgotten to plug it in, luckily for me before I put all the screws on the case.
To avoid losing any screws, print this guide and use clear tape to tape the screws next to the step. Use double-tape to avoid tearing or one of the tiny screws from falling out.
Good luck!
Thanks iFixit for helping me replace my MBP's keyboard!
Thank you for some excellent advice form JerseyJeep Gurl
Worked perfect on my 4,1 mbp. Took ~15 min.
I don't see a boost in speed... or is just me?
I used 500 GB 7200 RPM Seagate SATA Hard Drive model ST9500420AS.
(if has a G letter at the end (ASG) is the one with built in shock protection who conflict sometimes with the mac own G protection).
This guide was awesome. I used JerseyJeepGurl' s suggestion and used an egg carton, numbering each cavity as a step in the guide. So for a step that had me remove 3 different kinds of screws, I had a cavity for each, numbered: 1a, 1b, 1c and wrote a,b,c on the guide itself next to each bullet point in the step. It was awesome.
I guess that before starting I overlooked what a T6 torx actually was. I started this process at 8pm and realized right away that I did not have a set that small and of course all stores were closing. Lowes actually had an awesome fine torx driver set for only 7 bucks!
So that you fixit.
