Page 1 of 1
Installing MacBook Pro 15" Core 2 Duo Model A1211 Front Display Bezel
- Author: Ben Eisenman
- Difficulty: Moderate
Use this guide to replace a damaged front display bezel.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Display Assembly 8 steps
- Rear Display Bezel 5 steps
- LCD Panel 10 steps
- Front Display Bezel 9 steps
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
Edit
Step 20
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
Do not insert your spudger between the plastic strip and the rear bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 21
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 22
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Edit
Step 24
LCD Panel
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Remove the pieces of tape securing the display data cable and camera cable to the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
Remove the piece of tape securing the camera cable to the LCD.
Edit
Step 29
The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel. A heat gun may be helpful to soften the adhesive to prevent damaging the LCD panel during removal.
The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
Edit
Step 34
Front Display Bezel
Lift the inverter out of the clutch cover.
Do not pull the inverter cable too far out of the clutch cover, as its ground loop is very fragile and easily broken.
Disconnect the inverter cable from the inverter by pulling its cable away from the socket on the inverter board.
Remove the inverter and set it aside.
Edit
Step 35
If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
Edit
Step 36
Remove the single black Phillips screw from behind the display data cable.
Slide the small steel bracket away from the right clutch hinge and remove it from the clutch assembly.
If you have a Core 2 Duo Model A1211, there is no steel bracket. Simply remove the screw and continue to the next step.
Page 1 of 1
