Installing MacBook Pro 13" Unibody Upper Case
Add Note Introduction
Difficulty: Very difficult
The ins and outs of replacing your upper case.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Lower Case
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
first image
Add Note Step 2
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Step 3 — Battery
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Add NoteNotes: Step 3
Flag Reply by gansodesoya Dec 17 2009 @ 1:14 AM
why is step 3 necessary?
Flag Reply by MrKane Jan 5 @ 1:39 AM
Quote from gansodesoya:
Just to disconnect any power source to avoid damages by short-circuits.
Flag Reply by amiller770 Jan 30 @ 10:40 AM
Removes the possibility of any current flow. This is especially important if you are trying to mitigate the damage to the circuitry due to a spill on a keyboard.
Flag Reply by shockaaa 2 days ago
I'm thinking of ordering the spudger. I was thinking of order the heavy duty spudger... or should I just order the normal. Will either of the spudgers work for this DIY?
