Page 1 of 1
Installing MacBook Pro 13" Unibody Mid 2009 Subwoofer & Right Speaker
- Author: Walter Galan
- Difficulty: Moderate
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer and right speaker.
Sections
- Lower Case 2 steps
- Battery 1 step
- Optical Drive 8 steps
- Subwoofer & Right Speaker 3 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 3
Battery
For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Edit Step 5 ¶
It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
Page 1 of 1
