MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement
  • Add Note x
  • x 20
This guide will show you how to replace the SuperDrive from your laptop (requires a SATA SuperDrive).
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
first image
Add Note Edit Step 4 — Optical Drive  ¶
  • Using the flat end of a spudger, pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
  • Pry up from beneath the wires.
first image
Add Note Edit Step 5  ¶
  • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
  • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
  • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
first image
Add Note Edit Step 6  ¶
  • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
first image
Add Note Edit Step 7  ¶
  • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the two Phillips screws securing the subwoofer to the upper case.
  • The longer of the two screws is on the right.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
  • Lift the subwoofer off the optical drive, and set it above the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove the two Phillips screws securing the camera cable bracket to the upper case.
  • The right screw may remain captive in the camera cable.
  • Lift the camera cable bracket out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  • Lift the optical drive from its right edge and pull it out of the computer.
first image
Add Note Edit Step 12 — Optical Drive Replacement  ¶
  • Remove the optical drive cable by pulling it straight away from the optical drive.
  • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
For more information, check out the MacBook Pro 13" Unibody Mid 2009 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
